TwinTurbo.NET: Nissan 300ZX forum - thnx, in first gear for a while it would only get 0psi
Subject thnx, in first gear for a while it would only get 0psi
Posted by supersh0cker on February 02, 2011 at 9:11 PM
  This message has been viewed 179 times.
In Reply To If it's seized you'll see zero boost. A squeal only when... posted by Ted (92TT) on February 02, 2011 at 09:06 PM
Message but then it would boost up after i punched it, to it sounds like my turbo is getting stuck.. would changing the oil be a good idea and place to start, and i'll take off down pipes to look.
would it be ok to drive with a bad passenger turbo or will this make more problems?
